Quick question.
Quick question.
Can someone tell me if there are any cables (electrical) routed between the front mudguard and bottom fork yoke? Unfortunately many pictures that I took dont show the one detail I need. Even better if someone can post a picture of the wire routing around the yokes from the front that would be great!
SkidMark
SkidMark
Re: Quick question.
cant imagine there would be , but i could be wrong
- rmm355
- Bike Owned: 1999 CRM250 AR
Re: Quick question.
There is an electrical cable between mudguard and lower fork yoke. It is covered in flexi-conduit routed in the curve of the mudguard between the four bolts that hold the guard on. Off the top of my head I can't remember what wire it is but I can check when I get home. I remember the cable as I wanted to update my mudguard and needed to find a replacement with the rounded profile so the cable didn't get squashed when you bolt it up. I'll let you know shorlty, unless someone beats me to it.
Re: Quick question.
A reference photo from my bike stripdown, all you need I think
Re: Quick question.
thats great guys - thanks a lot. I thought it did because there are slight rub marks but couldn't remember for sure!
SkidMark
SkidMark
