CRM 250 ecu fix
CRM 250 ecu fix
Also you can get it fixxed to a greek guy, who 's doing a great job to electronic stuff and a full refreshment. The link has been reffered again but i think here is the right place to be put.
http://www.twostrokeracelab.com/search/label/PGM
You can also find him to the e-bay.
Alex.
Alex.
- crm250ar thailand
- Bike Owned: CRM250AR
Re: CRM 250 ecu fix
have you had an ECU fixed with him ?
or have you heard of anyone that used this service ?
what problems can he fix ?
Re: CRM 250 ecu fix
he can only fix the pv control side
Re: CRM 250 ecu fix
Several members have used twostrokelab and been very happy with the results. He can fix some faults but not others. It seems best to me to send him the 'faulty' ECU and get him to find out if he can fix it.
- crm250ar thailand
Re: CRM 250 ecu fix
might try it then
thanks
thanks
Re: CRM 250 ecu fix
Anyone know anyone who has successfully tied in the PV directly to the throttle cable on an MK3? I'm thinking of running premix and using the cable for the oil pump to control the PV. I rode with a guy today who did this to his DT200WR and it seemed to work great. He had the PV open at about 50% throttle. Bypass the whole CDU nightmare. Or is it not that simple?
