front wheel
front wheel
hi i have crm 250-2 that i got it a week ago it has a vabrtion in front wheel can some body can help me out.
regards
Alan
regards
Alan
john7780
- Bike Owned: crm 250 mk2
Re: front wheel
when does it vibrate? meaning at what sort of speed? i would suggest checking the bearings for any play or possible sticking, if theres no play then a good greasing may help, i had a mk2 that did it when i tested it down a private lane ( as it was road legal) but it only did it towards the top speed but i found very little play in the bearings, i did replace them and grease the spindle but never used it on road only off so i cant tell you how much difference that made
Re: front wheel
Check bearings as John says.
Also -
Check tyre is correctly seated on rim.
Check for buckling of the rim.
Some heavy rim locks cause 'hammering' when travelling at speed.
Check headstock bearings for play.
Also -
john7780
Re: front wheel
yep headstock bearings are a known culprit too, had that on an mtx 125
Re: front wheel
the front wheel make the nose like there is some thing hitting whit the spokes and just befor your changing gear
john7780
Re: front wheel
are you sure that noise is coming from the front wheel?
Re: front wheel
it seems that its coming from the front wheel.
Re: front wheel
Thanks a lot for your help i greased the front wheel and changed the break pads it seemes ok but i have to give him a long run.
Regards
Alan
Regards
Alan
