Pipes from carb
Pipes from carb
I'm looking for some help with some hose's coming away from the carb, i think i have all but one in the right place, the one i cant place is the braided one (roughly 13 inches) that come's from the large hosetail with the smaller bore, any help is much appreciated:) thanks in advance
Re: Pipes from carb
Two water hoses go from a little block on the carb held on by a single screw. One of these goes to the cylinder head and one to the RHS radiator.
Is this the one you mean
Re: Pipes from carb
Yes thats it:) are both hose's the braided ones? and does the one to the rad go to the rad itself or one of the hosetails on the coolant bottle?
Re: Pipes from carb
One from the bottom of the overflow coolant bottle goes to the connection just under the fill cap for the radiator the other goes out to the fornt down pipe on the frame and then down and acts as a drain.
Re: Pipes from carb
Ok knackered will sort that tomorrow and hopefully get the bugger running this week:) thanks for your help again, has been puzzling me for a while.
