which wires go to which pins number, on the LED control rela
hi guys
i hope you are well.
i need some information regarding wiring on an AR.
which wires go to which pins number, on the LED control relay on an AR?
The relay has 2 block connectors, one with 4 pins and one with 3 pins.
On our bike, the wires that should go to the 3 pin connector are snapped (so close to the connector i cant see the wire colour) - i need to know which wire colour goes into pin 1, which colour goes to the pin 2 (middle pin) and which wire colour goes to pin 3.
I have a manual and wiring diagram for the bike, but it only shows the 7 wires in total - not which pins each wire actually goes into in the block connector.
Any help would be greatly appreciated - photos would be really great.
The relay in question is called "control box" in the workshop manual. It controls the LED oil level and temp warning lights in the clocks.
The 4 pin block connector on our bike is ok - it connects directly to the dash (4 wires) to work the LED warning lights.
The 3 broken wires i need to rejoin go to the oil level warning switch (in the oil tank) and the PGM ECU (a signal for engine temp). I just need to know which wires go to which pins.
thanks
thanks
Re: which wires go to which pins number, on the LED control rela
I have my front end apart and so will look tonight - gotta go to work right now.
Sorry forgot all about this till I just happened to see your post again. the wire colours are as follows. I have numbered them with one being closest to the edge of the relay (the connector is in one corner). Maybe the diagram helps....lgingell wrote:hi guys
thanks
pin 1: green with blue stripe
pin 2 (middle): green with red stripe
pin 3: black
3 2 1 |
if its not clear let me know and I will take a picy for you.
Regards
SkidMark
oh shoot - ignore the diagram above - when it posted it shifted things around so it's wrong now...
thanks very much for supplying this information - its greatly appreciated.
ill let you know if the repair is successful!
hi
today, i succsessfully repaired the wires to the led control relay.
both the oil and temp warning leds now operate.
I cant thank you enough for taking the time to help on this one - its really appriciated.
I suppose thats the real benifit of the forum!
thanks again
leonard
LG Motorcycles
thanks again
leonard
LG Motorcycles
Skidmark - The only owner of an AR that hasn't been completely rebuilt .............................................. Yet
But has had a new Reg/Rec and ECU
ARs Rock
.................................... Whatever
ARs Rock
New Reg/Rec, used ECU and Servo Unit...knackeredMk1 wrote:Skidmark - The only owner of an AR that hasn't been completely rebuilt .............................................. Yet![]()
But has had a new Reg/Rec and ECU![]()
ARs Rock![]()
And my bike does rock - cos at the moment it is in the garage on a stand with no front end...so if I push on the headshock it does rock abit.....
