can someone direct me
Hi
New to the site. I've had a look around but not seen what I'm looking for yet...
Can someone direct me to the threads that deal with putting a CRM engine into a CR please?
Much appreciated
Spit
Much appreciated
Spit
Re: can someone direct me
None on here with regards to specifics but it has been done several times with both steel and aluminium frames. Things to remember are that there a lot more ancillary 'bits' with a CRM engine than a CR. e.g 2 stroke oil tank, PV servo, lighting related things .... Also that CRM engines will not fit directly into a CR frame and CR suspension will probably need 'softening' (depending on the ride desired).
The quality of conversions is variable if you get my drift
as a guide line if you decide to try it, it will take twice as long as you originally anticipated and cost even more than you could imagine
good luck and keep us posted
using that rule... I should have finished my build last month and have an extra thousands bucks in the bank :P
yes totaly agree.
also:
much better off spending your money on great suspension, breaks and wheels... make your chassis as good as a steel cr250 unit...
could even alter steering head angle for a couple hundred bucks.
if its purely for aesthetics then I cant help you there bud.
yes totaly agree.
also:
Thanks for the replies. I wanted to know because it's mentioned in July's TBM that it's not too difficult a job & results are better than modern tackle but the opinion here is that it is a big job, & that's beyond me
Thanks for the informative responses
Regards
Mark
Regards
Mark
if your an engineer/machinist you will find it to be a piece of cake
If you do engine rebuilds with your eyes closed, are handy with a welder and have friends with lathes etc you will find it challenging but not imposible
If your an average joe blog bike enthusiast then Id say you'd find it near impossible unless you had a deep wallet to pay the above mentioned people to help, or if you know some of the above mentioned people.
Also the CR and CRM ignitions/electrics are completely different, youd need to wire the bike up from scratch.
