new member
new member
just brought a mk2 crm250, bit of a heep,but i plan to keep it and restore it, it is a bugger to start but i think that maybe the piolet jet, where is the best place to buy spares. i need a speedo,ignition switch,switch gear,chain guard,new piolet jet
i would like some new plastics, does anyone do them or are cr250 ones the same?
i will post some photos when i get round to it.
Paul
Paul
voodookid37
- Bike Owned: mk1
Re: new member
hi raz....
most of your answers can be found here.....
viewforum.php?f=20
some very helpful lads an lassies on the forum and many diverse and wonderful rebuilds and make overs of all mk's ....d
viewforum.php?f=20
Re: new member
side panels are the problem ,if you can get them they cost a fortune over £140 for the pair when i looked into replacing mine ,so i went down the cr route and replaced pretty much everything ,subframe(modified) seat ,tank ,airbox & plastics for less than the price of the panels but spent a few hours in the garage making it all fit. Good luck theres plenty of help on here
Re: new member
Read the relevent articles in - viewforum.php?f=20 before you make big mistakes
(CRM125 parts for eg
Re: new member
can the rear shock be rebuilt? wheres the best place for discs/pads?
Re: new member
rear shock is rebuildable and discs pads are readily available i favour ebc not the cheapest but very good whatever the conditions
Re: new member
A good place to get parts from is leisure trail Iv got loads of stuff of em
Re: new member
its a good idea to get a price comparison against leisuretrails prices as at times they are on the expensive side of reasonable imo
Re: new member
got it going, new plug and pilot jet, runs pefect, front forks ok, back shock buggered, rear brake buggered, easy to ride with lots of low end power
