mk3 electrical fault
superbob
Post by superbob »
Hi guys try and stay with me here as I have a pretty big electrical fault I will try to explain as best as I can. The fault first started when I pressed the front brake lever all the instrument lights would flash all the other lights would go out and I would get a noise like a flasher unit clicking. Next it started to cut the engine out when I pressed either brake as well as taking all the lights out. Now I have investigated it further I have disconnected the indicators and the fault carried on so I checked the coil but there were no signs of damage. I have disconnected the front brake wireing and cleaned the kill switch after re building it seemed to be fixed however it only runs briefly then cuts out slowly. Anyone else had a similar problem or any help will really help to speed this repair up.
Re: mk3 electrical fault
Post by twistednuts »
Dont think there is a quick fix wi them electrickery gremlins.
Check all your earths, check condition of all the wiring behind the headlight, then start eliminating each switch etc. Guess you've eliminated it to a point but still not totally fixed.
Good luck dude
You have a short somewhere.
superbob
Post by superbob »
cheers guys I guess its a short Im going to have another look at the front brake an kill switch wiring as there seems to be a black wire the takes a feed from 1 2 the other bbut the wiring has been mucked about with in the past
shane
Post by shane »
Hi i have a very similar problem with mk2, did you ever find the problem
if i press the break at the same time as the lights on or the idacators the lights dim and the engine eventurly cuts out, i think its proberly shorting somewere but cant find any problem, do you have any tips?
many thanks
Bike Owned: KTM 200 exc
Post by back off road »
short or an earth fault either way it looks like a session with the avo meter :(
