Output shaft end play + balance shaft
- 250greenlane
- Bike Owned: MK 2
Hi I have a mk2 which seams to have a lot of end float on the output shaft (where the front sprocket fits) Im not sure if previous owners have lost a shim from inside the crankcases.So my question is how much end float is there on your output shaft? Also does anybody no the correct amount of end float on the balance shaft Cheers Glenn
- deano123
- Bike Owned: Two , mk2'S
Re: Output shaft end play + balance shaft
well will be out in the shed later to miss measure it for you
- Active Rascal
- Forum Ghost
- Bike Owned: CRM 250 AR
There should be absolutely NO play in the output shaft.... you might have to scrap your bike I think Glenn!!
Love Shaun x
Love Shaun x
+ no play in balancer shaft.
Output shaft bearing play is different from endfloat. There should be no play but endfloat isn't automatically a problem. I'd guess that most healthy motorcycle gearboxes have an element of endfloat.
Play nicely with Newbies, or you'll be" Round sack " washing duties for J7780Active Rascal wrote:There should be absolutely NO play in the output shaft.... you might have to scrap your bike I think Glenn!!
Love Shaun x
- Bike Owned: crm 250 mk2
There is no float or end play on my final drive shaft or balance shaft.
- deano123
think he means , when yo push/pull in and out of the case in which case there should be very small amount , but its normal, if theres none then things maybe tight of shimmed up wrong
- deano123
i meant output shaft , when it comes to balance then there should be none!!!
if its the balance shaft i believe you can run the bike with it disconnected anyway and it doesnt make much difference apart from being a bit vibey at top end, if its the output shaft then there may be a little bit of play in th way of push and pull but if theres any other movement theres something seriously wrong
- Active Rascal
- Forum Ghost
Definate scrapper!! ;)
The Mk1 has a compression type oil seal rather than the others that have conventional lipped seal (fits the same inside/outside diameter and thickness). I suspect the seal moves slightly when put under force but I can't feel it with my fingers.
- 250greenlane
- Bike Owned: MK 2
Thanks Lads, I thought the end play on my balance shaft and output shaft was excessive ,looks like a winter stip down on the cards
I will put on more details in the near future. Thanks again. Cheers Glenn
P S THANKS Shaun for your Bullsh t answer wait till i see you at work when you want so mods doing for you CRM/CR love Glenn
