bleeding front brake
- Bike Owned: crm 250 mk2
why wont my front brake bleed properly? has anyone got any tips of how i can bleed it by myself?
Re: bleeding front brake
Check out the search area, shed loads of post's on the subject.
Reverse bleeding is generally the way to go.
reverse bleeding?
If it wont bleed after reverse fill, it might need new seals on the plunger doins, the thing the lever pumps - cant remember the ruddy name of it now. Brake hose might even be goosed too, maybe worth investin in a braided hose, its meant to vastly improve front brake, which is pretty useless anyway
Reverse bleedin is fillin from the bleed nipple with a syringe kit
aha ill try that trick tomorrow and let you know how i get on. cheers lads
