coil??
- josh mk 2 crm
coil??
http://cgi.ebay.co.uk/OB-HONDA-CRM-250- ... 286.c0.m14
will this work on a mk 2 crm 250???
many thanks
josh
many thanks
josh
Re: coil??
As far as i know, they are all the same, but, does it look like yours,are you certain yours is not working.
- josh mk 2 crm
Re: coil??
hello
The only reason i am changing mine is because its abused by the old owner and is coverd in gaffa tape??
so iam thinking it might be a good place to start :s
does there need to be a certain plug cap on the bike???
Re: coil??
IMO, NGK, make about the best cap, which is one of their, red in colour, rubber, ones, they generally give a more water tight seal around the plug body, and have the resistor built in.josh mk 2 crm wrote:hello
