water pump?
water pump?
hi all, i have a few problems with the bike 1 is the clutch not disengaging. did a search and found it to be the basket had knotches where the plates sit. the other problem is a whineing noise from the right hand side. i have removed the clutch casing to sort the clutch problem and while i have it of , i have had a spin of the water pump. is it supposed to be tight and knotchy?. could this be my whineing.
thanks ste
thanks ste
Re: water pump?
Re: water pump?
how easy is it to check the balance shaft bearings?
