axle fitting
axle fitting
hi,
is it best to get a metal sleeve made up and welded in the end to make the fork clamp or are there any better ways ??
thanks nick.
thanks nick.
Re: axle fitting
why is your axle smaller anyway - using different wheels?
what about larger dia wheel bearings and the proper size axle ?
Spokey
Spokey
Re: axle fitting
you need to get the axle that was fitteed for those forks, and then either get a cr seal/cover for ther right hand side or machine the axle to fit the original speedo. Jon
Re: axle fitting
im losing the speedo.
is widening the original axle not an option? .
i dont think the guy i got the forks off has the cr axle.
also i didnt get the caliper bracket!!!!!
nick
nick
Re: axle fitting
found an axle now hopefully will be with me in a couple of days
just need to find the caliper bracket are most cr's have this bracket? looking on ebay cant find 91"
Re: axle fitting
i might have another around somewhere, ill have a look.
check out some other years around the same date i think there were a few
EDit, Just forund it, not A1 condition but should be ok if you want it, PM me
