Rad Valve
- outerwater
Rad Valve
Has anyone put a Boyeseen rad valve on their CRM Mk2 or know if you can do it if so do you know which part number it is.
Boyeseen website does not show it for CRM's but i would expect the CR's to be the same.
Any help.
Cheers from Downunder.
Outerwater.
Any help.
Outerwater.
Re: Rad Valve
I believe you can use the one for the CR250 1989 (which covers other years as well) but you need to take the brass oil tube from the CRM original and insert it into the Rad valve. You need to get a good seal on this.
Re: Rad Valve
I think the rad valve has a built in carb rubber which will prob be the wrong size and angle for a CRM. CR250 rubber for that year is for a 38mm carb
Better off with Boyesen petals for your block or a V-force for that year CRM
YES I can find ANOTHER use for a CRM engine, and YES Lee_P reckons it will be quicker than his FZR1000 in certain circumstances
