Rear Brake hose
Rear Brake hose
I know there are plenty of preople who have fitted front braided lines, including me.
Has anyone bothered with the rear, or knows what will fit?
I am just about to remove the swing arm to replace the bearings, so I have to dissconnect the hose.
Are the banjo bolts only good for one use? Do I need to corder new copper washers too?
Re: Rear Brake hose
Hi Scrubs,
Got mine from Hel Performance, they come come with all the washers and new banjo bolts you need, cost about £26 and were delivered in a couple of days.
Give them a try.
http://www.h-e-l.co.uk/
Hope this helps
pmac.
Give them a try.
Hope this helps
pmac.
Re: Rear Brake hose
Cheers Pmac.
That'll do nicely. Did you just go for the 'Honda 250 motocross' model?
Re: Rear Brake hose
Ignore that... I just seen they list a CRM250.. Jobs a good un.
Re: Rear Brake hose
Bottom of page 3 under Online Shop then Honda has CRM250 listed but has year '98 next to it.
