Blowy exhaust
Blowy exhaust
Okay, so fixed my end can, repacked with fresh packing, joined it all together and it sounds great but a bit blowy, especially around where the two pipes meet. I haven't used any exhaust putty stuff because i don't know if i should. What do you guys do? and also it's a bit blowy around where the alloy oval pipe is hexy bolted on? should i seal it around there too? ta, RD>
Re: Blowy exhaust
Hi RD what you need is a tube of RTV sealant 'this is a high temp silicone type sealant.Wynn's do a brilliant one thats in a pressurised cannister' it last for years and is always thier when you need it 'just read instructions first ***** p/s thats not kisses
that's the 5 star rating id give it
good luck
good luck
Re: Blowy exhaust
[quote="fallenmikethebike"]Hi RD what you need is a tube of RTV sealant 'this is a high temp silicone type sealant.Wynn's do a brilliant one thats in a pressurised cannister' it last for years and is always thier when you need it 'just read instructions first ***** p/s thats not kisses
good luck
Mike[/quote]
Cheers Mike, i'll get some!! RD.
good luck
Mike[/quote]
Re: Blowy exhaust
Dont worry Mike, there's a lot of it about at the momentfallenmikethebike wrote: 'just read instructions first ***** p/s thats not kissesthat's the 5 star rating id give it
Mud, Sweat and Fear
91-MK2
91-MK2
