Help! MK2 2 stroke oil res problem can you help?
Hi all, new owner rider here in herts, with a small problem.
yesterday i took my bike out for its first run and noticed as i wheeled it out of the garage a small pool of oil, ah nevermind i only wanted to go to the local pit.
after 7kms theengine made a rev related squealing noise and i stopped immediately.
got it home in the van and discovered that the sensor that plugs into the lower part of the resv was leaking around the wires and dribbling down the bike, hence the puddle. i have just squirted a little 2 stroke oil into the top. to keep it lubed up ok while it sits and i investiagte further, this is where you all come in..............................
have you got a spare for sale ?
could i cap it off with no difference?
or abandon it and pre mix into the tank?
what is an appropiate ratio to use with fully synthetic oil?
when i kick over the bike the oils comes out even more through the leaking part, why is this?
which is the best fuel to use on a mk 2 unleaded, super unleaded, or 4*?
cheers in advance chaps.
Nick
Nick
