Just bought my first crm250 but i got a small prob......
Hi all nice site btw
I've just purchased a 1991 crm250 which seems fine other than this small prob of chucking 2 stroke oil out of the breather pipe which dangles down from under the engine ..is this an overflow pipe?
If so why is mine chucking oil out when i ride? i've had to make a bottle up to catch it because it goes all over the back tyre
any ideas guys???
CRManiac
any ideas guys???
CRManiac
Thats not 2-stroke oil, that the engine/ gearbox breather, I rerouted mine to the airbox as it sucked up water for a while. you maybe over filling the gearbox. if you set the bike up on the level there is a 10mm nut with a crossthread in it on the right casing (not the one on the waterpump its a couple of inches behind this one). undo it and see if any oil comes out, if lots comes out let it drain as this is the level it should be up to.
if this doesn`t happen then its probably something to do with pressure in the gearbox but you will need someone with more 2-stroke knowledge than me, you should find plenty of help on this site with nearly 80 CRM owners. anyway hope its just the above. Phil.
