Cold Starting
dibateg
Cold Starting
Has anyone else experienced reluctant starting with MkII/2 CRM's?
Seems to be a too weak mixture. If you tip the bike on it's side long enough - it might start! The choke passages in the carb seems to have a drilling that allows to much air into the mix, so we've temporarily blocked that to see if it richens the mixture enough to start it on choke.
Be interested to see if anyone's had the same difficulties...
every model i have had inc the AR i have now is a cow to start when not been run for a few days. i find as soon as i park the bike turn the fuel off and like you say when i come to start it, turn the fuel on and lean the bike over, often goes after 5 kicks or so. interested to hear how you get on.
On another note - you get over to the horseshoe much ??
dibateg
- double_clutch
I never turn off my fuel and my bike always starts with 5 kicks.
When I first got my mk2/2 I used to knacker out myself by giving it loads of huge kicks (like on the CR250 I was used to) and it was a pig to start. this was really annoying when in front of friends
(mr Angry) who would laugh at all the effort I was putting in
Then I started getting used to the bike and found all I had to do was give it about 5 softish kicks without stopping and it would start like a dream and it still does. if you can get into a regular pattern of starting its easier to notice if somethings wrong.
Not so long ago I kicked mine about 10 times with no starting joy, took the plug out kicked it and there was no spark so I changed the plug, still no spark. then i removed the kill switch and cleaned the terminals then the bike started but ran badly. with all my engineering qualifications I carefully calculated nothing and wacked a scotchlock across the kill switch wires and the bike runs perfect all the time again.
SteveCRM
SteveCRM
- Russell
Strange how 2 bikes can be so different, if I forget to switch my fuel off the bike takes at least 10 kicks if not more to start, yet switch it off 3 kicks max.
I like you always used to leave the fuel on on all my other bikes, but had to start experimenting with the crm as can be very fussy starter.
I guess all crm's are slightly different and we need to try all options to discover the best method for the idividual bike.
i have a mk 2 crm, and have never had a problem starting it. i always kicks on the 3rd kick from cold with choke. i let it warm up for a minute or so, then ride on choke until i can feel the power come, then reach down flick the choke off, and ring it's neck. it is an awesome feeling to go riding with the 4stroke boys, and pull over to see what direction we're going, switch off the bike and know that it will start first kick when warm. my friends won't turn their bikes off for fear of kicking them over. ha ha ha - i guess the yz250f, and 400's aren't perfect after all.
go hard or go home
- double_clutch
