250AR - Help needed to establish wiring loom routing
- Pheasant12
Hi All
In need of some assistance please. I had a rectifier fail and it fried the PGM/ECU on my AR 1998.
I have had the PGM repaired by Nick in Greece and ready to reassemble and also have a new rectifier.
This occurred some time back and I did not take pictures of the rectifier loom routing.
As the exhaust and shock absorber are near, its a bit of a concern!
Can someone help me with this rectifier loom routing please and if possible, include some photos?
Re: 250AR - Help needed to establish wiring loom routing
This is from a MK3, but its probably the same/simular on the AR. It's not a great photo, but it show which way the cable goes around the shock. The frame should have a metal lug that the plug fixes to, so its not floating about (you can just make out another metal lug under the blue plug). I have some over photos of the loom, but none are that great.
