Mk2 oil pump fix
Mk2 oil pump fix
Hi all,
The brass nipple of the outlet has snapped. I read somewhere here that the nsr125 pump is almost identical and you can take the nipples of these.
I got my hands on a nsr125 pump but how do I manage to take off those nipples and put them on my crm250 pump?
Many thanks
Many thanks
Re: Mk2 oil pump fix
Grip between a pair of pliers and twist. Takes a bit of effort - pulling and twisting.
Thanks for your quick reply. So I assume it's better to take the pump of the engine when replacing the nipple right?
Not necessary unless it makes it easier to replace.
All right this worked out very well... Thanks help!
