Compression
- baggins1984
Compression
Good Morning CRM fans,
Would someone be able to compression test their bike when cold for me? I've done a rebuild (no rebore) because the compression was at 120 but after the rebuild I'm only getting 125?
I don't know what mine was putting out when warm as I replaced the piston due to it not running and it still won't start.
Re: Compression
Have you turned the fuel on to help seal the bore? I understand you have other issues with the engine.
Is there a decent spark?
Is fuel getting through to the combustion chamber?
Re: Compression
Just whipped the plug out of my AR and done some testing for ya.
130-135 psi (Fuel off)
150-155 psi (Fuel on)
Both tests at WOT and engine cold.
Fresh top end (bore,plate, piston, rings, bearing) just run in.
- baggins1984
Re: Compression
Thanks gents. When the fuel is on I'm getting 125 so seems low compared.
Re: Compression
Why didn't you do a rebore?
- baggins1984
Re: Compression
There wasn't any scoring so didn't think it would be necessary. Should I have?
Re: Compression
It's not necessarily scoring but wear. You should have measured the bore. BUT to be honest if you are replacing the piston and you have low compression you should have had a rebore.
- baggins1984
Re: Compression
Yeh I'm wondering whether it's the wear that's causing the low compression. To be fair I did take it to a bike garage and the guy just told me to get the same size piston that I had removed.
- baggins1984
Re: Compression
One more question, so the compression is about 125 cold. I know that's low but wouldn't it still start but not produce very much power? Mines not even hinting at a start
Re: Compression
should still start I would say.
Need to check a load of things now:
Fuel getting to cylinder
Spark
Reeds (should still run unless non existent)
Timing (some have had woodruff keys fall out/shear meaning the rotor turns on the shaft)
That's about it really
Spark
- baggins1984
Re: Compression
Yeh it's weird. All of the above are fine. I've fitted a new dep pipe aswell. It replaced an old dep pipe so it shouldn't need rejetting should it?
Re: Compression
nope. when did it run last? did you try a bump start?
Re: Compression
how old is fuel?
- baggins1984
Re: Compression
I stripped it diwn this time last year, painted frame etc,fitted exhaust. Bike started fine but was running badly,bogging down when I tried to rev it. Was trying to sort that when it just cut out and I haven't been able to start it since.
Fuel isn't too old, I put fresh in after I had rebuilt the bike.
That's when I replaced the piston thinking that was the issue but still no joy.
Spark us fine, plug is wet when I do try and start it.reeds are fine.carb is clean as a whistle.
Re: Compression
crank seals? you should do a leak down test really to check!
https://www.duncanracing.com/TechCenter ... sstest.pdf
