oil pump oil seal and balance shaft
Hi everyone i cant find the oil pump oil seal on the micro fiche does anyone know where i can get one from i want to replace it as a precautionary measure.And is it possible to replace the balance shaft bearings without a major strip down or is it possible to remove the balance shaft altogether ? i cant believe i didnt replace the bearings when i rebuilt the engine i just overlooked it but i do remember checking all the bearings.I have a very slight rattle from the area of the balance shaft but other than that shes running like a dream
Re: oil pump oil seal and balance shaft
Balance shaft bearings can be done with engine in bike and minimal stripping (clutch and flywheel off).
It can be removed using a spacer but I have tried and it was too vibey for me alhough others dont mind.
Make or borrow the tool to get the bearing out though unless you want the greif I had. see thread below.
viewtopic.php?f=6&t=9744&hilit=balance
- 2016NWAA
The balance shaft bearing/shaft when it goes is a very distinctive high pitched whirling noise and not a slight rattle.
A slight rattle or knock sounds more like the clutch so you might be lucky and not have anything to do.
[quote="Eddie Evans"]The balance shaft bearing/shaft when it goes is a very distinctive high pitched whirling noise and not a slight rattle.
A slight rattle or knock sounds more like the clutch so you might be lucky and not have anything to do.[/quote
+1 , they will go on for years with the bearing whining without any implications.
It could also be powervalve flutter.
I did balance shaft recently, it had whined since I bought it back in 2010.
I was lucky, in as much as mine came apart with the use of a socket as a drift.
If you do strip it, pay particular attention to the spacer washer on the shaft, other wise you have to get creative with an angle grinder to get it back in place
speaking from experience
