MK2 wont tick over
Re: MK2 wont tick over
Post by twistednuts »
You can test the float valve, but only to a certain extent, by checking it while the float bowl is off.
Whilst the carb is off, leave the float bowl off, connect the petrol pipe to the carb and hold the carb in your hand whilst switchin on the petrol. Do this over a bucket for obvious reasons.
If you gently lift and drop the float you can check the operation of the valve. Its only a rough test, but it can be helpful. Also give the float a shake to make sure its not damaged and lettin fuel in.
;) Wonder web, other guides available. google tuning, [your carb].
http://www.carbparts.com/keihin/needles ... r_carb.htm
Cadiddy
Post by Cadiddy »
Right, I've reset the float hight using the the method described in that link (thanks mike) and just to double check the mk2's float hight is 16mm right? The old man is gunna run the bike up and see how it is tonight hopefully as i'm back away at work until friday so will update when i can,
Thanks for all your help chaps really appreciated:)
njhardy
Forum Regular
Forum Regular
Bike Owned: CRM250 Mk3
Post by njhardy »
Tang height is 16mm from top of float to carb body- just when it touches the valve pin to stop the petrol flow. Check the tickover needle for cronk blocking it and open the air/mixture screw 1 1/4 turns from fully closed. Make sure petrol is flowing into the float chamber when reconnected by opening the float drain screw.
Cadiddy
Post by Cadiddy »
Right so Dad ran it again last night after i reset the float hight and was no different in fact petrol was pissing out the over flow, and it would stop when he hit the kill switch or the ignition all of a sudden, any ideas what might have caused that?
Cadiddy wrote:Right so Dad ran it again last night after i reset the float hight and was no different in fact petrol was pissing out the over flow, and it would stop when he hit the kill switch or the ignition all of a sudden, any ideas what might have caused that?
Pure coincidence I would say, the floats are either duff, i.e. not floating, or the inlet valve is still sticking open.
There seems to be more than one problem going on here.
Try and get a reliable petrol supply before moving on to other area's.
Cadiddy
Post by Cadiddy »
Well guys i finally found out what it was.... Was the slide not seating proper so she's all back in as should be and running like a dream:) feel a bit stupid now i know what the problem was,
Thanks guys for all your help really appreciated
Cheers n gone
Cadan
john7780
Bike Owned: crm 250 mk2
Post by john7780 »
told you to check the slide, always start with the easiest option
Bike Owned: KTM 200 exc
Post by back off road »
:geek: well done john go to the top of the class and give the pencils out :lol:
john7780
Post by john7780 »
hell yeah i just love it when im right, in ya face knackered ;)
oi trevor you coming fat cats this saturday?
:( working mate
john7780
Post by john7780 »
back off road wrote::( working mate
you and me are gonna fall out ;)
