SO where do i start ?
Re: SO where do i start ?
Hi ya Twisted , im going to try and convert it to CR ,plastics, tank, seat ,airbox,and rear subframe
rephrase that i am going to
P.S. Your coffee has gone cold mate
Good cos i have tea...
You've made a mess of the rug already la! Hahaa
Looks like ya got ya work cut out, have fun dude
Hope the Mrs doesnt notice the rug , im doing the bike while shes at work lol
if you want tea you will have to bring you own ,we dont drink it
john7780
- Bike Owned: crm 250 mk2
no need john, mines working fine and id like it to stay that way lol
thanks for the offer tho
End of day 1
Crm bits stripped off
easyest bit done , CR front mudguard fitted
original tank mounts (at least ) will need removing to allow CR tank to fit
subframe will require a little fabrication to fit ,but it will give the slightly taller seat position i hoped for
mount to fabricate for ECU and reg / rectifier due to CR having open topped airbox
At least i can see where im going now (up to the garage when time allows) lol
john7780
shame that i owe you a broken front brake for all the stick youve given meback off road wrote:no need john, mines working fine and id like it to stay that way lol
work is progressing
managed to get a bit more done today on the alterations , subframe cut and rewelded , alteration to frame for front top subframe mount , bars & new hand guards fitted ,new headlight in place and wired up , once subframe has been painted airbox and plastics to refit , rear light to connect up and mount numberplate to fit and should be ready to ride
Well done
. How are you going to fix the tank
You are also going to need to find a space for the rear brake fluid reservior.
the subframe cut & rewelded , luckily the throttle side leg bolts straight up when the carb rubber is on so only one leg needs altering and the top mount
rear brake reservoir fits to the original mount ,but there is the small matter of the brake light switch mount ?(thanks for reminding me Knack ) Tank mounts are going to be fabricated off the top engine mount i think , as i dont think the tank shroud mounts onto the rad will be sufficiant . Where did you get the pressure switch for the brakes ?
Re reservior - Forgot you have a Mk2
Pressure switch - eBay though they have gone up in price.
a good weekend nearly finished
maybe a ride round the block later no chance of going any further
The conversion is finished but the bike is not
I am going to replace the used panels with new ones to tidy the bike up
things are going well but the red panels all seem to be PINK been as Barbie has gone ,pinky is too obvious the hybrid must be PERKY as its pink and a bit of a pig lol
