input shaft bearing
Re: input shaft bearing
Actually I would use the Suzuki part as it is a different design. Whilst the Honda bottom end bearing would probably work fine the Suzuki one is designed as a transmission bearing.
- pudzie83
- Bike Owned: mk2 1992
you beauty mate i think i could have a problem solved http://www.ebay.co.uk/itm/111444270057
That's the one I would go for though I'm pretty sure there is no difference.
- pudzie83
After a little google search i found this http://www.partzilla.com/parts/detail/h ... 3-873.html so onto a winner here i think
That's good because I trawled the web and could only find Russian or Polish sites that might have had it.
- pudzie83
to anyone that needs to use a rmz bearing you have to add a 1 mm washer behind the clutch basket but my engine is now running very sweet and alot less quiet
nice one bud
- pudzie83
there was alot of play/rattle in my clutch shaft bearings now there is none at all
this could easily be confused with the balance shaft bearing as well!
personally i think the bearing has been on its way out since ive owned it but credit to the build quality of the crm engine its lasted
- pudzie83
Quick update the rmz bearing with a 1mm spacer behind the basket case is solid Weston beach race tested
495th out of well over 800 (registered)
Well done Pudzie!
- pudzie83
Cheers mate i had an amazing time this time round no back injury holding me back the madam performed flawless as well the bottom end polish and match work was very noticeable
out of us cov lot that went the crm came first the ''dinosaur'' is the 2016 champion haha
^^^^^^ Champion, well done mate.
- pudzie83
Cheers mike the other lads got involved in crashes and had failed and sunk bikes i just plodded to victory
They got a whole year of captain slow here (on the old bike may i add) rubbing it in haha
