Blinkin ek that mudguard is shinny !
Some nice bling there
Thats down to the sheer amount of paint i used on the thingjompy wrote:Blinkin ek that mudguard is shinny !
The Nissin brakes are off the bike and have been stripped down
the bleed nipple though is seized in nicely and because its made of cheese, the nut has been rounded off in an attempt to remove it. all i can think of is to apply some heat and force on a smaller socket. otherwise its a new calliper
id like to keep the original lever really but it is looking tatty and the rubber on the master cylinder is starting to perish
original hose i presume, judging by the patina
get yourself a braided hose i think they're between £30-40 , master cylinder should be fine but if you do want to sort out the rubber boot the part number is 45504-410-003 and they're just under £10 for an O.E.M one or you can try some where Like Leisure Trail and ask Tom how much an aftermarket one is i know M&P do a kit for £20ish . You may want to buy newer calipers i'm sure the nissins were used on a lot of bikes but not sure what fits what so it would take some digging around
I have already (see last updatejompy wrote:get yourself a braided hose i think they're between £30-40 , master cylinder should be fine but if you do want to sort out the rubber boot the part number is 45504-410-003 and they're just under £10 for an O.E.M one or you can try some where Like Leisure Trail and ask Tom how much an aftermarket one is i know M&P do a kit for £20ish . You may want to buy newer calipers i'm sure the nissins were used on a lot of bikes but not sure what fits what so it would take some digging around
- nicko
- Bike Owned: Mk3
Have you come across brake banjo bolts with integrated bleed nipple? Not the neatest solution to a seized original nipple but functional
CRM Mk3, billet clutch basket
i like the look of thatnicko wrote:Have you come across brake banjo bolts with integrated bleed nipple? Not the neatest solution to a seized original nipple but functional
I havent seen one before, no. But im assuming it replaces the standard banjo bolt and allows you to bleed the brake from the end of the hose?
Sean
Sean
- nicko
- Bike Owned: Mk3
yup, exactly as you described sean.
Can be a bit difficult getting the last bubbles of air out when bleeding because the standard nipple is usually placed at the highest point of the caliper so that any bubbles rise up through t'nipple & so with the banjo replacement nipple you may need to unbolt the caliper & rotate it a bit to get the new nipple to the top.
I managed to get the bleed nipple out this morning and ive taken the calipers down to the powdercoater for paint. Thanks for the tips
im not even sure this one is worth an update but i have the pictures so here it is....
24 years of rust and dirt on the rear wheel cams lets the look of the shiny swingarm down, i wanted to get them shot and powdered but i thought the pressure of the wheel nuts might cause the powder coat to crack, so i did it myself instead
i got an 80's makita drill for jobs like this, i put a wire head on it and grinded the cams down to good metal
i got the sandpaper/wet n dry out and my girlfriend wanted to help, so i did one and she did the other. teamwork! She actually seemed quite proud of herself
in the hands of my new assistant...
i used heat dispersant engine paint because you can apply it thin without primer and it still dries hard
done
done
good idea
only now have i just found new CNC cams on ebay for 25 quid... Well nevermindjompy wrote:good idea
Im looking for one of those stickers for the speedometer that converts it from kmh to mph, does anyone know where i can get one?? Cheers
