Mk2 Resorection
Re: Mk2 Resorection
A bit more done today , had to make a generator holding tool
That did the trick !
Building the clutch back up I decided the tab washer had seen better days so off to leisure trail for a new one & some coolant .
Found a few things out today like when you buy the aftermarket clutch steels you get one extra & the tab washer that holds the inner clutch basket on is s**t , as I torqued the nut up the washer spun with the nut bending the tabs , I didn't notice at first and put the cover on & it got jammed on the bent tab washer !
So bottom half of the engine is is about there , generator cover needs to go on , barrel needs and head need to be torqued down , I've sourced some new pipes for the 2 stroke oil pump and the car de-ice pipes .
Re: Mk2 Resorection
Well got some more done yesterday and today even with a few hold ups , was hoping to fire it up but ran out of time , the garage is ditched !
Just needs gearbox oil , coolant and petrol , already checked for a spark & fingers crossed the gears are OK
Re: Mk2 Resorection
Well had it running today , already knew the brakes were binding so they're next
http://vid185.photobucket.com/albums/x1 ... EO0005.mp4
Re: Mk2 Resorection
Well that's another £160 spent on brake seals front & rear , chain slider , braided front hose , dot 4 and cheap aftermarket levers . Unfortunately one of the front caliper bolts & the bracket seem to be catching the disk :O
Re: Mk2 Resorection
How long do you think it'll be until shes roadworthy? Looks like your not too far off
Sean
Sean
Re: Mk2 Resorection
Rear brake , think I have a bent front disk but have 2 spares , may fit my other wheels so I can check the rims on these as I think the rear is corroded so that means bearings ,new pads & fit the chain slider so other than tidying it up which will be next year I'm aiming to get it mot'd in Feb
Re: Mk2 Resorection
Cool, im hoping to have mine ready before christmas as well. id be interested to see some more pictures of yours when its finished, seeing as mine had the same paint scheme/graphics as yours once apon a time...
Sean
Sean
Re: Mk2 Resorection
my rad scoop graphics are in a bad way , my look at getting some one to knock some up for me in the future
Re: Mk2 Resorection
In the garage today to sort out the stuck caliper pin , managed to free the caliper but disaster struck trying to get the pin out !
Brand new vice I'd just fitted !
Now just need to drill the pin out , replace the pin & sort out the locating guide I snapped off a couple of weeks ago .
Re: Mk2 Resorection
That's a good advert for a Clarke vice.
I've got one so will have to be careful with it.
Did you see my email re rear brake bracket?
Re: Mk2 Resorection
i did have the caliper to the far side of the jaws & was swinging on the vice handle to tighten it up but i still wouldn't expect that !
Andrew you are a star buddy , your Email had gone to my junk folder so thank you for mentioning it here !
£10 should cover the postage if your ok with that and do you have paypal so i can get the wife to send you the money ?
I'm down your neck of the woods next weekend visiting the wifes friends and family in bridgend , the wife used to work for JT's & Thunder road in bridgend & also M&P's many moons ago
Re: Mk2 Resorection
If you would prefer to look at the bracket and decide whether you want it when you're visiting next weekend that's fine by me. I'll check postage cost tomorrow. I do have a Paypal Acc but have only ever used it to pay for things!
It really is great having M&P on the doorstep. They had a fire which destroyed their warehouse some years ago. It has since been replaced which a really smart facility.
Re: Mk2 Resorection
The wife used to work for them about 20 or so years ago [emoji38] the contacts Jen has is amazing , I'm happy with the bracket bud I'll Email you my address so you can send it & let me know what I owe you , if your happy with PayPal I'll send the money through that , if not I'll sort something out with you
Re: Mk2 Resorection
Paypal will be fine.
Re: Mk2 Resorection
jompy,
Bracket posted today should be with you by Thursday
