Idle not steady
Re: Idle not steady
if the valve is moving then you cant fault the ECU repair as he only replaces the bridge on the ECU responsible for servo movement.
I know that the ARs dont have a steady idle because there is a valve controlled from the ECU that moves the idle up and down. Remove the cover from your carb and you will see.
