Shock Bearings / Swing arm bearings are no more!!!
Re: Shock Bearings / Swing arm bearings are no more!!!
I think the caged bearings may have a couple of rollers less than uncaged.
£2 bargain.
£2 bargain.
thats some good news for once!
actually I did get some bargains on the bearing front.
for instance my main bearings were a fiver each new ( japanese made too! )
jus the weird size ones ( balance shaft particularly ) I had to use LT - and that shot the price up..
lets see if they last a couple of years...
pretty much replaced every bearing in the engine.
and the suspension -
and front yokes- actually struggling to get bottom bearing for yokes on - i put yoke in fridge hoping that will help - but wondering how to heat the bearin up..
maybe I need a pipe to bash em on? ( worried these were from LT so not so cheap.. ) ( i know saw some on ebay later
You can stick the bearing in your oven for half an hour. I normally set oven at about 150 degrees Celsius. Only problem is food tastes of oil/grease for a few meals
Simplybearings are quite good for bearings and seals in the UK
How would sticking the bearing in the oven help
Bearings in the oven, swingarm in the freezer = fun and games
For the swinging arm bearings, the reverse would be the case, heat the swinging arm, freeze the bearings, but generally a good vice and an appropriate sized socket normally suffices.
steering stem...
yep socket did the trick on the swinger...
think I need to find a bit of pipe the right size? worried I will break the Leisuretrail supplied bearing..
and looking at the races in the headstock with horror!!!
FMtB +1 with heating and cooling.
Yep, a bit of pipe to match the top of the bearings diameter, and nylon or copper hammer, oh, and a big dose of machismofishtail wrote:steering stem...
honestly u'd think I'd get better with a hammer, ( ie hitting tube not hand is desirable!! ... anyways its on! and I had a little dance
I said bollox to the races - they didnt look too notchy and frankly I've had enuff for now!
