Clutch problems
Re: Clutch problems
FMtB - Why would that happen
. Even with severe rust the organic plates wouldn't stick with the oil in them
Bet it turns out to be the cable.
Re: Clutch problems
The plates could have warped, this would give rise to the stalling when a gear is engaged, which is essentially the problem as I understand it, no?knackeredMk1 wrote:FMtB - Why would that happen. Even with severe rust the organic plates wouldn't stick with the oil in them
Once on the move, drive isn't the issue.
Re: Clutch problems
Yes
- you are right if the steel plates were warped.
