ar in glasgow, scotland
lgingell
Bike Owned: CRM 250 AR W
Re: ar in glasgow, scotland
Post by lgingell »
hi
the spring i removed from my ar measured up as a 80n/mm.
Knackered - where did you find the spec of 7.5?
i weigh 15 stone if full enduro gear, and use a 105 n/mm spring to get the correct loaded and unloaded sag.
if you have 100 race sag (roughly correct, well done!) but no static sag - this means too soft a spring with too much preload.
as a general rule use 2-15mm preload to achive correct static and race sag.
Jon - how much preload are you using to achive 100 race sag? i assume a lot more than 15mm.
if you tell me all of the measurments from the bike, i could help calculate correct spring rate.
to work out my spring rate i needed
static sag
race sag
spring rate
i used an online spring rate calculator
http://www.pontiacracing.net/js_coil_spring_rate.htm
a stiffer spring with less preload will actually give a softer, more complient ride in the first half of the suspension stroke.
lgingell
Post by lgingell »
i have a 90 n / mm spring that will fit an ar shock you can try if you want?
its a ktech spring to fit a ktm, 250mm long and 63mm internal diameter (i think).
it retails for £80 new, i am open to offers.
I bought it new, fitted it to my ar, set the sag, realised it was still to soft and removed it.
I fitted a 105n/mm and now have the correct static and race sags.
i weight 15 stone in full enduro gear.
7.5 is in - http://translate.google.co.uk/translate ... n%26sa%3DG
There are also springs advertised on Rinkya and elsewhere that take the original rate of 7.5 upto ? (usually 9.0).
lgingell
Post by lgingell »
i could be that the standard ar spring is a 7.5.
i think the optional 6.5 spring may be for lighter riders. possibly less than 9 stone.
if the standard 7.5 spring was too soft to give the correct sag, then a stiffer spring is the obvious option.
the correct spring rate can be (aproximatly) calculated as long as you have the following information
current spring rate
installed length ( or how much the spring is preloaded)
static sag
race sag
its a pitty you guys were not near glasgow.
i would be happy to help you do a set up
lgingell
Post by lgingell »
Just a quick update,
i bought another bike
a ktm exc 200 gs (autolube).
This brings my garage so far to
honda crm 250 ar w
honda cb 250 fx hornet
honda cb 500 w
bmw r1100rt
ktm exc 200 gs
Volvo 850 t5
delvey91
Post by delvey91 »
Ahh the EGS, did you buy the one that was on ebay a few weeks back, it was for sale in scotland somewhere if i rememeber. If it wasnt so far away i would of deffo bought it, was mint!
99 HONDA CRM250 AR MUGEN
KTM 525 EXC SUPERMOTO 05
lgingell
Post by lgingell »
Yes it was in inverness, 4 hours north of me, so pretty far from any of you guys in england.
The drive was definetly worth it.
The bike is mint. The guy was the origional owner, and had done around 1000 miles, mostly on the road.
It has the origional front tyre on it!
Its certainly not new any more - ive done 3000 k so far, and spent around £1500 on making it more suitable to race.
mods so far
105 n/m shock spring
5.0 n/mm fork springs
black bodywork, ktm decals and yellow number boards (for clubman class enduros)
sump gaurd
hand gaurds
flywheel weight
grips lockwired
grip donuts
larger pegs - (buzzeti 55 x 90 mm)
fork socks
shock sock
brake pads
v rorce 3 reed block (very much recomended)
42 t rear sprocket
clutch saver
12 different main jets
7 different needles
6 different pilot jets
3 different throttle slides ((£130 each!)
new piston
thinner base gasket
air filter
irridium plug
repack silencer
the compression is now 220 psi, and its very very fast! Suspension is still a little on the soft side, but much better than CRM.
It is not as good on the road as the CRM, and the finish is falling apart very very quickly. Parts fall off regularly.
I cant wait to race it!
Overall i would very much recomend it.
woolley
Bike Owned: AR
Post by woolley »
is it for sale pics please
cheers
wool
