wierd problem??
josh mk 2 crm
Re: wierd problem??
Post by josh mk 2 crm »
hello
i managed to find an old post on here about testing the stator and the reg/rec,
i used the info about using a 12 v battery on the under seat 2 pin connector from the reg/rec and you will never guess what. . . . . . . . my CDI is bust (it got hot and started smoking!!) so the hunt is on for a CDI unit!!
just thought id keep you updated on the situation.
nackerd CDI's can cause no spark but everything eles works?
josh mk 2 crm
Re: wierd problem??
cheers for the heads up!
oh no the item ended early!
i wonder who bought it :)
my bike should be fixed in a few days now! :) :) :)
josh mk 2 crm
Re: wierd problem??
Thank you all for your help! ( i know its an old post but i thought i better say thanks)
all sorted CDI/reg/rec fault plus a nackerd flywheel and woodruff key!
sorry i forgot to mention that i bloody love my bike at the moment! :)
http://www.facebook.com/home.php?#/albu ... =599960448
1st time out with no problems :)
but i do need a clutch cable any cheap ones off other honda's that will fit!!
