REAR BRAKE PIN LENGTH ?
Any ideas what length the rear brake pin is please, I know the front is 55 mm and I have replaced this with the hex type pin,just need to do the rear now , could it be 75 mm?
thanks ( and yes I did search.. )
MK3 SuperMoto (now sadly sold 04/08 )
MK2.2
MK2.2
Re: REAR BRAKE PIN LENGTH ?
Hi chippy,
Ive just measured my Mk 2 pin and the pin part is 53mm, overall length, including threaded part is 70mm.
Regards KK
Regards KK
Thanks KK, I will order a 75 mm, that should do the trick
MK2.2
MK2.2
I have a spare short one (bought for the back of the R1, which turns out to need a long one.Chippy wrote:Thanks KK, I will order a 75 mm, that should do the trick
FTAGH.
